TwinTurbo.NET: Nissan 300ZX forum - Checking circuits - running/parking lights
Subject Checking circuits - running/parking lights
Posted by scorp997 on August 10, 2020 at 11:17 PM
  This message has been viewed 256 times.
In Reply To Actually I had only checked the main front and rear turn posted by Rossm952 on August 10, 2020 at 10:40 PM
Message The lights are controlled in separate circuits, each with their own fuse. Headlights, brake lights, turn signals, and running/parking lights.
It sounds like the brake light circuit is ok, as is the turn signals. We are trying to determine if your issue is a fuse, wiring/sockets, or bulbs. All of the running/parking lights are controlled together, so f none of them work it is a circuit failure - most likely a fuse.
If you turn the light switch to the first (parking light) or second (headlight) position, do ANY of the exterior lights (front corner and rear corner markers, rear tail lights, license plate, or dash gauge lights) come on? That is the first thing we need to know in order to help you.
Check and get back to us.
