TwinTurbo.NET: Nissan 300ZX forum - there is a foam or rubber spacer on the inside lip of the
Subject there is a foam or rubber spacer on the inside lip of the
Posted by slayer fan on August 10, 2020 at 9:11 AM
  This message has been viewed 230 times.
In Reply To Is it normal for the rubber around the headlight to shrink.. posted by nelso419 on August 09, 2020 at 11:30 PM
Message headlight gasket. it is only on the bottom where the seal meets the bumper. it doesn't go around the whole perimeter of the light if i remember correctly. you could take the lights out and form a spacer to encircle the inside of the seal. this would push out on the seal and eliminate the gap. i replaced both of my seals a couple of years ago and had to transfer the spacer from the old seals onto the new. i used weatherstrip glue to keep the spacer in place. hope this helps.
