TwinTurbo.NET: Nissan 300ZX forum - How to change block oil galley & brass plugs?
Subject How to change block oil galley & brass plugs?
Posted by DanielThomas on August 06, 2020 at 10:15 AM
  This message has been viewed 280 times.
Message Hi guys
I'm doing an engine build and last time i did it only changed the core plugs, this time i bought the 4 block oil galley plugs and brass plugs from CZP to change whilst i change the core plugs.
Problem is i'm not even sure where they are located, let alone how to remove them
I'm planning to have them out, bore out the water passages a little then get the block acid dipped to hopefully clean out the oil galleys aswell.
Any tips would be greatly apprechiated
