TwinTurbo.NET: Nissan 300ZX forum - Re: How much of a PITA is it to replace A/C compressor?
Subject Re: How much of a PITA is it to replace A/C compressor?
Posted by Metacom on July 26, 2020 at 10:35 PM
  This message has been viewed 370 times.
In Reply To How much of a PITA is it to replace A/C compressor? posted by doug8867 on July 26, 2020 at 12:44 PM
Message NA's are easy and straight forward. No real secrets, removing the fan and shroud will give you plenty of space to work with and can pull it up and out w/ a stock radiator or remove the sway bar to go through the bottom.
Had to replace the one on my TT twice and I have a Koyo radiator in. With the fan / shroud off and sway bar removed it drops out through the bottom. Little more tricky with the turbos intake/boost hoses, I didn't need to remove all the hoses like the FSM indicates.
