TwinTurbo.NET: Nissan 300ZX forum - Re: Did you replace the o-ring between the filler neck and tank
MJzTTZ
on July 21, 2020 at 12:27 PM
Did you replace the o-ring between the filler neck and tank (n/m)
posted by ctheobal
on July 21, 2020 at 10:29 AM
Yeah i did that. The leak is coming from some of the bolt holes. From research it looks like they are suppose to be blind holes. I poked a wire through them and some of them go all the way through into the tank.
Fuel tank questions/suggestion needed
MJzTTZ
10:12:09 07/20/20
ctheobal
10:29:00 07/21/20
Re: Did you replace the o-ring between the filler neck and tank -
MJzTTZ
12:27:07 07/21/20
Bummer. Good luck. (n/m)
ctheobal
20:07:53 07/21/20
Re: Bummer. Good luck. (n/m)
MJzTTZ
22:19:45 07/21/20
Permatex permashield resists gasoline. If the threads are
mrchips
07:12:36 07/22/20
Re: Permatex permashield resists gasoline. If the threads are
MJzTTZ
07:37:40 07/22/20
