TwinTurbo.NET: Nissan 300ZX forum - Re: Need help/ideas. I had my oil pan replaced at the
Subject Re: Need help/ideas. I had my oil pan replaced at the
Posted by Metacom on July 10, 2020 at 2:59 PM
  This message has been viewed 255 times.
In Reply To Need help/ideas. I had my oil pan replaced at the posted by doug8867 on July 09, 2020 at 08:43 PM
Message Check your brake switch bumpers haven't deteriorated away on your brake pedal.
https://conceptzperformance.com/nissan-infiniti-nissan-oem-clutch-brake-pedal-switch-bump-stop-nissan-240sx-300zx-46512-h0101_p_5090.php
If they're intact, try adjusting your brake switch. If not that, your switch is stuck or an extremely unlikely short in the circuit.
If your battery is only reading a flat 12v (should be 12.5 or 12.6) its discharged and only requires a recharge. If the battery is ok your ignition switch could be suspect if you get zero anything with the key in.
