TwinTurbo.NET: Nissan 300ZX forum - also, when adding r134,the high side valve on the
Subject also, when adding r134,the high side valve on the
Posted by slayer fan on July 07, 2020 at 5:55 PM
  This message has been viewed 311 times.
In Reply To yours appears to be correct. turning the valve to posted by slayer fan on July 07, 2020 at 05:19 PM
Message manifold itself should be closed. the high side quick disconnect should be open so you can see the high side pressure. the first time I did it I had both valves open on the manifold and the can would not empty. as soon as I closed the high side, everything went smoothly. good luck.
