TwinTurbo.NET: Nissan 300ZX forum - Re: Struggling with A/C low cut sensor issue, any A/C experts?
Subject Re: Struggling with A/C low cut sensor issue, any A/C experts?
Posted by Metacom on July 06, 2020 at 9:01 PM
  This message has been viewed 355 times.
In Reply To Struggling with A/C low cut sensor issue, any A/C experts? posted by Polishzx on July 05, 2020 at 09:52 PM
Message The dual pressure switch "reads" off high pressure side line pressure.
The high pressure side needs to be approx 23 PSI + before the switch will allow the compressor to turn on when first refilling the system after a complete evac. It takes mine a couple minutes before the can can pump enough refrigerant into the low side line to build up enough pressure in the high side before the switch will allow the compressor on.
