TwinTurbo.NET: Nissan 300ZX forum - I would think the Clog would effect Vacuum
Cjw3
on July 06, 2020 at 2:12 PM
Correct, native r134a on a 94. It seems like the valves can
posted by Polishzx
on July 06, 2020 at 01:04 PM
The debris drying to come out I'd think would clog the Valve, butting Liquid in would blow the Debris back into the System to get Lodged in the Evaporator.
Good Luck..
Cj
Struggling with A/C low cut sensor issue, any A/C experts?
Polishzx
21:52:00 07/05/20
The AC does not Pull the Refrigerant in
Cjw3
06:46:57 07/06/20
So I guess my issue is low pressure side is not taking charg
Polishzx
11:55:47 07/06/20
'94 is a Native R134.. Yes?
Cjw3
12:21:18 07/06/20
Polishzx
13:04:14 07/06/20
I would think the Clog would effect Vacuum -
Cjw3
14:12:01 07/06/20
Schrader valve
megaDan
08:22:14 07/07/20
harbor freight manifold gauges? (n/m)
slayer fan
15:15:58 07/06/20
if so, my quick disconnects were mislabled for
slayer fan
15:31:01 07/06/20
I am using the harbor freight manifold gauges!
Polishzx
16:25:27 07/07/20
yours appears to be correct. turning the valve to
slayer fan
17:19:00 07/07/20
also, when adding r134,the high side valve on the
slayer fan
17:55:36 07/07/20
Re: Struggling with A/C low cut sensor issue, any A/C experts?
Metacom
21:01:07 07/06/20
xarcos
15:21:17 07/07/20
