TwinTurbo.NET: Nissan 300ZX forum - '94 is a Native R134.. Yes?
Subject '94 is a Native R134.. Yes?
Posted by Cjw3 on July 06, 2020 at 12:21 PM
  This message has been viewed 309 times.
In Reply To So I guess my issue is low pressure side is not taking charg posted by Polishzx on July 06, 2020 at 11:55 AM
Message If the System is an r-12 Convert, then Likely the Conversion Nipple is not installed properly, and the Schrader Valve is not being Depressed..
But I think the '94 was native R-134, so a Conversion Nipple is Not used.. however the Same Problem can still Exist.. the 'Quick Disconnect' still needs to be able to Depress the Schrader on the System.. Is it possible that your 'Device' is not activating the Schrader properly?.. Try Opening the System under 'Vacuum' and see if you get a Sucking Sound.. I know if you do, you'll have to pull Vacuum for another Hour to get the Containments out.. but that is the Only cause I can think of fore the Freon not to go in the Low Side..
Is your Vacuum Fitting the Same Fitting you are using for the Freon Introduction?..
Cj
