TwinTurbo.NET: Nissan 300ZX forum - So I guess my issue is low pressure side is not taking charg
Subject So I guess my issue is low pressure side is not taking charg
Posted by Polishzx on July 06, 2020 at 11:55 AM
  This message has been viewed 335 times.
In Reply To The AC does not Pull the Refrigerant in posted by Cjw3 on July 06, 2020 at 06:46 AM
Message e at all. The system is under vacuum correctly. I let it sit under vacuum for an hour to verify no leaks, and also ran vac pump for 45 minutes after that before filling. AC system under vac, r134a can hooked up, low pressure side opened and I see the low pressure gauge go well above 20 PSI, like ~40 or 50. No refrigerant can be seen evacuating through the window, it seems like the can is not filling the system at all and gauge is showing the pressure of the can. Any other reasons why the low pressure side wouldn't take on any refrigerant?
