TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Did you remove or unplug the HICAS module?
Subject Re: Re: Did you remove or unplug the HICAS module?
Posted by scorp997 on June 27, 2020 at 4:14 PM
  This message has been viewed 323 times.
In Reply To Re: Did you remove or unplug the HICAS module? posted by maur010 on June 24, 2020 at 05:46 AM
Message DVDBURN is referring to the electronic module under the passenger footboard. He is correct that the HICAS module is also the power steering control in a TT (not on a NA model).
If I read your post correctly, you have removed the HICAS hydraulic ram in the back and replaced the ram with an elimination bar then plugged the hydraulic lines. Did you install a bypass line at the solenoids in the front engine compartment?
If you didn’t bypass the lines, the second stage of the PS pump could become hydraulically locked..
