TwinTurbo.NET: Nissan 300ZX forum - First start up, terrible noise
Subject First start up, terrible noise
Posted by twin3037 on June 19, 2020 at 9:05 PM
  This message has been viewed 378 times.
Message The 91 twinturbo has been down for about 6 years. Finally finished re-building almost every part of the car: Harness, turbos, injectors, transmission, o2 sensors, and deleting AIV, and EGR.
I left the top and bottom end alone as the car was running strong before re-build and tested 160-165 compression on every cylinder.
Finally got the car started and it makes an awful noise and is throwing a code 34. Detention sensor and harness are brand new and i confirmed with bore-scope that they are tight, not pinched, and in the correct plug. Video of noise on start up below:
https://drive.google.com/file/d/1L9cYYxknwEktWVwiGlkA10L9puU2JZk3/view?usp=sharing
While the engine was out i didn't touch the timing belt as it was done 5k before engine out and just replaced the alternator, power steering, and ac belts.
Any Ideas?
