TwinTurbo.NET: Nissan 300ZX forum - My quick thought is a bunch of green corrosion
Subject My quick thought is a bunch of green corrosion
Posted by FrozTTy on June 16, 2020 at 1:13 PM
  This message has been viewed 265 times.
In Reply To 91 TT Starts but dies after short idle. TPS, fuel pump??? posted by Eleanor 18 on June 14, 2020 at 06:52 PM
Message in your wiring harness.
When you can get it started, does the idle surge to around 2k rpms, and once it settles it then dies?
Or does it not surge at all, just limp and die?
Other than corroded wiring, I'd say MAF, CAS, TPS.
Also, I hope you changed the oil after it sitting for so long. If not, do this ASAP. Did you drain the fuel? If not, I'd put some Dry Gas in your tank and get fresh 93 in there ASAP.
