TwinTurbo.NET: Nissan 300ZX forum - Re: Replacing driver side door glass
Subject Re: Replacing driver side door glass
Posted by MyBlueZ on June 09, 2020 at 8:36 PM
  This message has been viewed 365 times.
In Reply To Replacing driver side door glass posted by TTTy(Dallas) on June 09, 2020 at 08:09 PM
Message Have you completely removed the glass from the door already? If so, those three rollers that go in the slides are removed from the roller side of the glass (inner side). It may not look like it, but there's a center cap covering a screw in the center of each roller. Use something small and thin and pop off that cap. Unscrew the roller, then use snap ring plyers to spin off the disc from the button that goes through the glass.
You can kind of see how it fits together from the pics of the replacement kit -- https://www.z1motorsports.com/door-shell-and-trimming/nissan/oem-300zx-z32-top-window-roller-slider-kit-p-4398.html
I actually had to take more drastic measures to get mine off because a few were fused on. I cut the roller post off with a hacksaw and then drilled out the center of the button threads without going through to the glass. Then gently pried the disc off. It was a PITA.
