TwinTurbo.NET: Nissan 300ZX forum - Checking the detonation sensor and wiring is a really good
Subject Checking the detonation sensor and wiring is a really good
Posted by SirpriZ on June 06, 2020 at 2:13 PM
  This message has been viewed 341 times.
In Reply To Previous owner had the car in storage for years in Texas posted by Shutoburner on June 06, 2020 at 08:12 AM
Message idea. If the detonation sensor is triggered, that would put the car in safety boost which is 6 psi. I had an issue with my wiring when the car was four years old and with 25k miles. When you drop the down pipes (again; that's gotta be getting old), you might also try is to put shop air (with a gauge on the line) to the wastegates. See if the wastegate mechanism itself starts to open at it's designated spring setting. That should give you some additional data to determine if the wastegates are opening when they should, and to bypass the boost solonoids. Are your wastegates and the signal to them stock?
