TwinTurbo.NET: Nissan 300ZX forum - New TPS issue.
Subject New TPS issue.
Posted by ttboy on June 06, 2020 at 2:51 AM
  This message has been viewed 379 times.
Message So I just installed a new OEM Throttle position sensor, dialed it in to .48V at idle, with the hard idle switch on (using ECUtalk).
Now here's the thing: At WOT, I only get 3.88V. The specs say it should be 4 to 5 Volts at WOT.
When I slapped the old one back in to compare, it still shows 4.2V.
So the question is, at what Voltage does the ECU trigger the WOT response? Is it 4 to 5 Volts?
Does you guys have a new TPS and what voltage are you getting at WOT?
Sheat.
