TwinTurbo.NET: Nissan 300ZX forum - No dice, Help?
Subject No dice, Help?
Posted by twin3037 on May 31, 2020 at 4:12 PM
  This message has been viewed 300 times.
In Reply To Do you have this posted by Cjw3 on May 31, 2020 at 09:39 AM
Message Re-did all grounds, ran extra straps between every ground and an additional location. Checking continuity at all 4 engine harness ground locations show they are grounded.
But when i check the harness at the ECU location pins 50 and 60 still show no ground continuity. Is it possible these pins aren't meant to be grounded without the ECU plugged in or a relay kicking in?
Originally started check because the ECU won't enter diagnostics mode.
