TwinTurbo.NET: Nissan 300ZX forum - Any tricks to remove ignition lock barrel shear bolts?
Subject Any tricks to remove ignition lock barrel shear bolts?
Posted by Gordo LSZ Daytona on May 30, 2020 at 1:48 PM
  This message has been viewed 385 times.
Message The bolts used to clamp the ignition barrel to steering column are shear bolts, and once tightened the head shears off so they cannot be undone.
I want to tighten the barrel to the steering column. Either by tightening the bolts, shimming it, or removing the shear bolts and replacing with normal ones.
Specs on Nissan shear bolts
Thread: M8x1.25
Thread Length: 18mm
Head Diameter: 11.5mm
_________________________________________________
