TwinTurbo.NET: Nissan 300ZX forum - Can you check the ECU Water Temp Sensor
Subject Can you check the ECU Water Temp Sensor
Posted by Cjw3 on May 21, 2020 at 9:48 PM
  This message has been viewed 245 times.
In Reply To Intermittant miss, lean idle, rich under boost posted by Red Hawk (CO) on May 21, 2020 at 03:27 PM
Message If the water sensor is 'Bad' the ECU will approximate what the water temp could be.. and it will be very predictable, and it will 'Start Cold' every time you restart the Engine.. You can check it my looking at the ECU's water temp from the Laptop.. let the temp rise, then Shut it off, and restart.. if the sensor Info is 'Synthetic' it will start displaying the water temp as cold again..
This still does not explain the entire scenario you are seeing, but this is all I got presently..
Cj
