TwinTurbo.NET: Nissan 300ZX forum - Intermittant miss, lean idle, rich under boost
Subject Intermittant miss, lean idle, rich under boost
Posted by Red Hawk (CO) on May 21, 2020 at 3:27 PM
  This message has been viewed 327 times.
Message I have a weird one that just started. Cold start up, the car idles perfect for roughly 30 seconds, then it suddenly runs super lean (17-19afr) and starts this light, random miss. It will do this routine consistently and at the same time interval as if something switches over in the ecu. As the car warms up it will immediately begin the miss and lean idle regardless of time from turning the key. Under boost it will run rich (10-11afr). I just tested for vacuum leaks and found none. it almost appears to be a metering issue? Could it be a bad maf or Selin translator? I have version 1. Thanks!
