TwinTurbo.NET: Nissan 300ZX forum - Re: Re: OK.. this info helps
Subject Re: Re: OK.. this info helps
Posted by Cjw3 on May 15, 2020 at 12:01 PM
  This message has been viewed 232 times.
In Reply To Re: OK.. this info helps posted by eldergolfer21 on May 15, 2020 at 11:06 AM
Message From my experience, Cam Timing and Cranking Speed are big Factors in Equal Pressure Loss.. the Other ones are Not Opening the Throttle Plate and /Or Not pulling all the Plugs to get breathing back from now 'Vented' Cylinders to prevent Intake Suction from Affecting Cranking pressures..
I'm thinking at this point it really does not make much of a Difference your actual Compression pressure, as long as to do not have any Bad Defects in the Motor.. Like Leaking by the Rings/Excessive Blow by.. Oil Consumption Issues, or Exhaust Smoking.. Or Bad Cylinder Drop test..
It is curious as to why.. if someone is going to put a tune in that motor, they should check it's health, and if you have issues, it will get found..
Cj
