TwinTurbo.NET: Nissan 300ZX forum - OK.. this info helps
Subject OK.. this info helps
Posted by Cjw3 on May 15, 2020 at 2:21 AM
  This message has been viewed 274 times.
In Reply To Re: Re: Low compression on all 6 after doing full OEM gasket kit posted by eldergolfer21 on May 14, 2020 at 08:14 PM
Message Now I know a little More.. We have a Running Rebuilt Engine with Low Compression..
Its not an Oil Thing.. This was just a 'Top Rebuild' so the Bores should not be a factor.. With the Compression being mostly the same through the Cylinders, it's sounding like a Cam Timing Issue.. Or a problem with the Compression Tester.
Can you source a Differential Compression Tester ( Leak down Tester ) to verify Bores and Valve Leaks?..
Is it possible the Head Gaskets are Thicker than before?..
Cj
