TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Low compression on all 6 after doing full OEM gasket kit
Subject Re: Re: Low compression on all 6 after doing full OEM gasket kit
Posted by eldergolfer21 on May 14, 2020 at 8:14 PM
  This message has been viewed 260 times.
In Reply To Re: Low compression on all 6 after doing full OEM gasket kit posted by Cjw3 on May 14, 2020 at 03:07 PM
Message I'll try the oil
I did not deck the heads. I took the cam shafts out while the heads were off to do the valve stem seals and then put everything back as it should. Did everything individually. Nice and organized.
The only note that I will make is that the spark plugs were very black except for a little bit on the tip. Spark plugs were in very good condition before. I suspect it's just from the new base tune running a little rich to be on the safe side. I have about 50 miles on the engine right now, post refresh
