TwinTurbo.NET: Nissan 300ZX forum - Re: Low compression on all 6 after doing full OEM gasket kit
Subject Re: Low compression on all 6 after doing full OEM gasket kit
Posted by Cjw3 on May 14, 2020 at 3:07 PM
  This message has been viewed 262 times.
In Reply To Low compression on all 6 after doing full OEM gasket kit posted by eldergolfer21 on May 14, 2020 at 01:41 PM
Message Check your Cam Timing.. Your not off by a lot, and it just might be dry cylinders.. If the Cam Timing is Good, try a little Oil in the Bores and see what happens to pressures..
Did you Deck the Heads.. This will change the Cam Timing, and if a lot was taken off, You might need Adjustable gears to get the Cam Timing back
Cj
