TwinTurbo.NET: Nissan 300ZX forum - Low compression on all 6 after doing full OEM gasket kit
Subject Low compression on all 6 after doing full OEM gasket kit
Posted by eldergolfer21 on May 14, 2020 at 1:41 PM
  This message has been viewed 301 times.
Message Not sure how this happened, but I replaced all the gaskets (including head gaskets) and torqued new OEM head bolts and washers down per factory spec. I have not done a boost leak test or checked timing yet. Before performing refresh, cylinders averaged 150 +/- 5 psi.
Full disclosure, I only tested cylinders 1-4 and they were all right at 125psi. I assume the drop was consistent across the board.
Not sure it matters, but I also upgraded, at the same time, to 2.5 in. manifolds, 2.5 in intercooler piping system, and bigger throttle bodies. Had a base tune done by Specialty-Z.
Any help would be appreciated
