TwinTurbo.NET: Nissan 300ZX forum - Re: Would anyone know the bulb numbers for the following
Subject Re: Would anyone know the bulb numbers for the following
Posted by Jinjiro on April 20, 2020 at 8:29 AM
  This message has been viewed 246 times.
In Reply To Would anyone know the bulb numbers for the following posted by SirpriZ on April 19, 2020 at 03:30 PM
Message 1. Neo Wedge T4
2. Neo Wedge T5
3. Neo Wedge T4
If you're planning on using LEDs, SuperBrightLeds.com has them. I just did it, they drop right in, although the plastic base is a bit softer than the stock. You'll want to use some pliers or a small screwdriver to gently lock them into place.
If replacing all lamps with LEDs, this is what you'll need:
Temp Pod (Right):
2x 5mm NEO5-x lamps
1x 3mm NEO3-x lamps
Lighting Pod (Left):
5x 4mm NEO4-x lamps
