TwinTurbo.NET: Nissan 300ZX forum - Need help! with AC/Heat issues
Subject Need help! with AC/Heat issues
Posted by iAustinian on March 09, 2020 at 8:35 PM
  This message has been viewed 290 times.
Message Need help diagnosing a heat issue. I think its the heater valve but I cannot find anywhere online on where to find it in the car. I found some very old threads relating to the issue but they are full of dead links. If anyone has any insight on how to fix the issue it would be appreciated!
the blower works, and its the digital climate control on the drivers dash. The water lines on the engine side of the car dont seem to be flowing the hot water? and the AC does not function. I have the automatic digital pod and it’s a 90'. When I change the temp the vents swap, and same for recycle/eco. It’s almost as if the heat doesn’t reach from the heater core to this valve, as if it’s stuck in the cold position
