TwinTurbo.NET: Nissan 300ZX forum - I switched over to the GM style J connectors to
Subject I switched over to the GM style J connectors to
Posted by jzack on March 08, 2020 at 11:08 AM
  This message has been viewed 255 times.
In Reply To My explanation isn’t clear posted by ZXRider on March 08, 2020 at 03:43 AM
Message avoid needing the clips. But even with that better connector some locations were still a challenge to access.
If you grind off the plastic orientation pin on the FICD connector body, OEM connector can be reoriented as needed. FICD is not polarity (voltage) sensitive.
FYI - I spliced a male/female crimp connector onto one of the wire leads for that connector. Made it extremely easy to disconnect the FICD from the cars system without having to remove the whole connector plug.
