TwinTurbo.NET: Nissan 300ZX forum - Re: Check engine light
Subject Re: Check engine light
Posted by ThisIsSparTTa on February 29, 2020 at 6:28 AM
  This message has been viewed 225 times.
In Reply To Check engine light posted by AnimalZTT (TX) on February 28, 2020 at 10:34 PM
Message Either you didn't do the test right or the potentiometer on your ECU is broken.. You should get the 55 code if everything is good, not solid. Which if the CEL is on, it's not all good.
You can also grab a USB to Consult reader on eBay and use it with ECUTalk.
