TwinTurbo.NET: Nissan 300ZX forum - If its a bent rod you can fix it relatively easy.
Subject If its a bent rod you can fix it relatively easy.
Posted by volcomstone550 on February 26, 2020 at 5:59 AM
  This message has been viewed 225 times.
In Reply To Got project running, but it has low compression. Need advice posted by Polishzx on February 24, 2020 at 06:34 PM
Message If it was me i would yank the motor and just swap the rod with a new rod bearing.
If you want to be less cheap... Pull all pistons and rods and re-ring all 6 cylinders with oem rings and get 6 new oem rod bearings.
If it was me i would dingleberry hone it get aftermarket oem bore je11:1 pistons+ scat rods and put some boost and E85 on it.
[url=https://ibb.co/edHzmK]
[img]https://preview.ibb.co/mMFkRK/IMG_20180713_193021_
033.jpg[/img][/url]
