TwinTurbo.NET: Nissan 300ZX forum - Found the issue!!!
Subject Found the issue!!!
Posted by Duke0477 on February 10, 2020 at 11:44 AM
  This message has been viewed 176 times.
In Reply To Bummer, but it does further narrow things down. posted by Polishzx on February 03, 2020 at 10:19 PM
Message Found the issue. It turned out that the cable from starter solenoid to the starter motor had broke at the terminal. I could not see this until I pulled the starter. I re-ended the cable with a beefier connection, reinstalled, and the car started right up.
I am happy to have the car fixed, but upset to see how flimsy a terminal connector was used on this remanufactured starter. That is not even a wire you mess with as that portion of the wiring is pre-assembled.
It was a good learning lesson.
Now onto replacing the alternator harness.
