TwinTurbo.NET: Nissan 300ZX forum - Front washer booster pump options
Subject Front washer booster pump options
Posted by Shutoburner on February 10, 2020 at 7:58 AM
  This message has been viewed 318 times.
Message I have a major leak around the front pump by the PS wheel well. It’s leaking around the plastic on the pump itself. I looked up the part #
28920-31P00 and it’s discontinued. Got a replacement at rock auto and has the large orifice meant for the rear. I can probably rig it if I got the adapters but looks a bit painful. I tried to just change the lower gasket/seal on the older OEM pump and it still leaks around the housing. Long story short, is there a factory style replacement with two small nipples for the washer lines? TIA...
