TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pressure
Subject Re: Fuel pressure
Posted by MyBlueZ on January 29, 2020 at 11:59 AM
  This message has been viewed 258 times.
In Reply To Re: I second this, I've seen the FPM have intermittent posted by thumper300zx on January 28, 2020 at 08:45 PM
Message If fuel pressure doesn't bleed down, your fuel pressure regulator could be bad. Or your return line to the tank could be blocked I guess. But even that, if you pulled the relay and cranked it over it should have dumped whatever pressure it had into the injectors. I found this post on here from Greg at Specialty Z a few years ago that I always refer to when thinking about fuel system related issues.
[ http://twinturbo.net/m/nissan/300zx/forums/general/view/2610744/Here-is-how-it-works.html ]
Not sure that really helps but it might give you some things to look at.
