TwinTurbo.NET: Nissan 300ZX forum - Fuel pump module may be failing when it gets hot. It
Subject Fuel pump module may be failing when it gets hot. It
Posted by mrchips on January 28, 2020 at 7:40 AM
  This message has been viewed 260 times.
In Reply To Unfortunately, the new fuel pump has not solved original iss posted by thumper300zx on January 27, 2020 at 10:02 PM
Message controls the ground for the pump. Run a ground from chassis to the white wire at pump when it screws up and see if the problem goes away.
