TwinTurbo.NET: Nissan 300ZX forum - Timing crankshaft gear wont go back in.
Subject Timing crankshaft gear wont go back in.
Posted by slcZ32 on January 14, 2020 at 11:08 AM
  This message has been viewed 233 times.
Hello all, I'm trying to replace the timing belt on my tt. The motor is out of the car at this moment making things a bit easier. It was a PITA to remove the crankshaft gear, I had purchased a new oil pump so, to remove the gear I had to destroy the current oil pump casing(hammered the gear out with a pry bar).
Anyways, I'm trying to put the crankshaft gear back on the crank but it does not go back in. I have tried to tap it, grease it but nothing.
Any tips? I don't want to damage the crankshaft or the gear.
