TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Update, no major progress
Subject Re: Re: Update, no major progress
Posted by mrchips on December 30, 2019 at 6:48 AM
  This message has been viewed 253 times.
In Reply To Re: Update, no major progress posted by Metacom on December 29, 2019 at 11:20 PM
Message Use a test light to check switched power at solenoid first. It should be as bright as using it across the battery. If good, hook a jumper cable from battery negative to the starter housing. If it now spins, the ground is your problem. If not, the starter, the power cable or battery/connection is suspect.
