TwinTurbo.NET: Nissan 300ZX forum - Update, no major progress
Subject Update, no major progress
Posted by Polishzx on December 29, 2019 at 3:47 PM
  This message has been viewed 245 times.
In Reply To My 94 A/T NA Will not crank, why!??! posted by Polishzx on December 17, 2019 at 03:34 PM
Message Tried the following with no change:
-Swapping out Ignition and EFI relays in driver side engine bay fuse block.
-Disconnecting security system even further
-Conzult shows "Start" signal when I turn the key to start, so ignition switch is at least working.
I used an older used battery cable on this car. The split room around the battery cable is slightly eaten up but it appears to be in otherwise good shape. Would the battery harness being old cause a no crank?
