TwinTurbo.NET: Nissan 300ZX forum - Re: Re: USDM Clock fix (revisited)
Subject Re: Re: USDM Clock fix (revisited)
Posted by lymon on November 12, 2019 at 10:55 PM
  This message has been viewed 384 times.
In Reply To Re: USDM Clock fix (revisited) posted by thumper300zx on November 12, 2019 at 07:24 PM
Message on a standard board you should measure a short (zero resistance, full continuity) between all different color sets, so zero resistance between red & red, zero resistance between blue & blue and zero resistance between yellow & yellow.
If you do not measure a short between one or more of the passthrough joints/points then solder a wire in place. (or just do all, just to be safe)
the wires do not bypass the resistors, they basically bypass/replace the traces on the display side of the board that have lost connection with the component side of the board.
