TwinTurbo.NET: Nissan 300ZX forum - I hade my rear axles rebuilt. They were OK, but I
Subject I hade my rear axles rebuilt. They were OK, but I
Posted by Gordo NA2LS Daytona on October 04, 2019 at 5:24 PM
  This message has been viewed 323 times.
In Reply To changes or upgrades to subframes? posted by The Fairest Lady on September 30, 2019 at 05:53 PM
Message wanted new rubber accordion sleeves. $75 ea.
Its also a good time to drain and refill rear diff.
With KW V3?s you are already going have a pretty hard suspension. Now is the time to rethink poly bushings; you have an option of softer Nismo on most of the control arms and other parts like the diff.
It sounds like you have the bushings covered, but just to insure that; here is a full kit, front and rear.
2 Front Lower Control Arm Bushings
2 Front Tension Rod Bushings
2 Front Stock Sway Bar Bushings
2 Rear Stock Sway Bar Bushings - TT only
2 Rack & Pinion Mounting Bushings
4 Rear Differential Carrier Bushings
4 Rear Subframe Bushings (optional)
18 Rear Control Arm and Shock Bushings (optional)
Finally, I took the opportunity to clean up all of the underside, especially the areas concealed by the subframe. Your gas tank is aluminum underneath all that gunk, and it looks great cleaned and polished.
_________________________________________________
