TwinTurbo.NET: Nissan 300ZX forum - Re: Do you have a Horn Under there?.. Is that the wire?
Subject Re: Do you have a Horn Under there?.. Is that the wire?
Posted by goldman on September 19, 2019 at 4:29 PM
  This message has been viewed 220 times.
In Reply To Do you have a Horn Under there?.. Is that the wire? (n/m) posted by Cjw3 on September 18, 2019 at 01:38 PM
Message Thanks for all the help everyone.
Yes, I believe that is where the blue wire is going to. I did not know the car had a seperate theft alarm. It is buried good as under the plastic battery tray is a metal plate that holds the battery up. Two twelve or thirteen mm bolts hold the tray in. I took them out to see if I could 100% be sure that is where the wire was going to, but after removing the two bolts, it looks like the holder is tack welded on, so i reinstalled the two bolts. With the plastic tray out you can see the alarm horn. Do not know how one would ever replace it if they had to. Anyway thanks again for help in solving this mystery. I can see when a car sits you have to lift the hood often to keep critters out. now I have mice/rat block poison under the hood.
