TwinTurbo.NET: Nissan 300ZX forum - Hmmm, 60 is what I get fan blasting, set at 60.
Subject Hmmm, 60 is what I get fan blasting, set at 60.
Posted by Tanley (ATL) on September 14, 2019 at 5:13 PM
  This message has been viewed 231 times.
In Reply To Re: I think what he was getting at was 40 degrees F doesn't seem posted by Metacom on September 14, 2019 at 04:34 PM
Message The chart in the FSM is fan blasting. Did you see the note about putting into test mode in the FSM? I'm not even sure if recirculation is on in that mode. I haven't seen anything saying what exactly the mode does, other than setting the system to the highest fan speed. Since the system is designed to run continuously. The temps at idle might not be that great, because at higher RPMs the evaporator could freeze up?
