TwinTurbo.NET: Nissan 300ZX forum - Cig lighter fuse sits loosely...
Subject Cig lighter fuse sits loosely...
Posted by thumper300zx on August 26, 2019 at 8:48 PM
  This message has been viewed 312 times.
Message Was troubleshooting why my cig lighter works intermittently (I use for BT FM modulator with USB). It finally seems to have completely stopped working. I have no voltage at the lighter. I went to check fuse and found it barely holds on. It will literally just fall out, springs don't clip at all...no pressure. The fuse itself is fine. Can you kinda pry those contacts out to create pressure again? I can barely see the contacts because of the position of this fuse. Will I need to remove the entire fuse box to do so effectively?
VISIT thumper300zx.com for PICS and TECH PAGES
