TwinTurbo.NET: Nissan 300ZX forum - Re: Could be the coolant sensor is a little off? Could run
MJzTTZ
on August 21, 2019 at 9:37 AM
posted by jzack
on August 21, 2019 at 08:53 AM
ok ill try that. Thank you
engine temp, ignition, IACV question
MJzTTZ
21:07:13 08/20/19
200 seems a bit high, 180 is usually as hot as
JMartz
07:17:57 08/21/19
Re: 200 seems a bit high, 180 is usually as hot as
MJzTTZ
07:37:59 08/21/19
jzack
08:53:03 08/21/19
Re: Could be the coolant sensor is a little off? Could run -
MJzTTZ
09:37:49 08/21/19
Got the IACV idle issue fixed.
MJzTTZ
23:19:26 08/21/19
I would replace both temp sensors to be sure
platinumist
18:05:42 08/22/19
I know there is a temp sensor on the coolant hardpipe where
MJzTTZ
19:05:39 08/22/19
There's 2 on the hardpipe. One gives a signal to the ECU.
MixManMash
23:00:11 08/22/19
Oh ok... I will change those out and see. Thanks (n/m)
MJzTTZ
23:31:26 08/22/19
I think you have a cooling problem that doesn't exist.
SirpriZ
15:56:44 08/26/19
Using my OBD2 scanner on my 1996 TT >>>>>>>
JULIAN
17:09:46 08/27/19
