TwinTurbo.NET: Nissan 300ZX forum - That pipe is bolted to the head
Subject That pipe is bolted to the head
Posted by Broke_as_**** on August 10, 2019 at 2:18 AM
  This message has been viewed 321 times.
In Reply To Coolant leak help request posted by Danbarnett123 on August 09, 2019 at 09:34 PM
Message If you get the fan and shroud off you can remove the upper coolant pipe that has two short hoses going to either head. The two short pipes going from the head to the upper coolant pipe hoses can be removed and resealed with silicone and the short hoses replaced. Fairly cheap job if you can do it yourself.
