TwinTurbo.NET: Nissan 300ZX forum - Definitely the cheap injectors
FrozTTy
on July 22, 2019 at 9:44 PM
1993 TT - Idle and Turbo Boost issues after Cheap injector
posted by LA z
on July 22, 2019 at 06:41 PM
These cars are particular and should only get the best.
Make sure you lube the o-rings prior to installation so they don’t get pinched.
LA z
18:41:04 07/22/19
Definitely the cheap injectors -
FrozTTy
21:44:11 07/22/19
If your going to Troubleshoot, Get Conzult and a Cable
Cjw3
17:40:48 07/23/19
Re: Thanks for that info Cjw3. I did not know. See amazon
LA z
19:38:30 07/23/19
To: Cjw3. Is that the one? See Amazon link
LA z
21:47:53 07/23/19
I got mine years ago from Z1
Cjw3
06:56:04 07/24/19
Re: 1993 TT - UPDATE for some advice on RE-INSTALL of NEW...
LA z
10:30:06 07/30/19
Change the engine temp sensor
FrozTTy
07:25:33 07/31/19
Also make sure your TPS is working properly and you
FrozTTy
13:53:38 07/31/19
Re: Also make sure your TPS is working properly and you
LA z
12:25:04 08/01/19
www.yugobernie.com/injector.html
00:21:49 08/07/19
