TwinTurbo.NET: Nissan 300ZX forum - If the clutch surface looks good, it could be that the coil
cherry
on July 17, 2019 at 2:21 PM
You might need to replace the clutch. ...Or you could
posted by cherry
on July 17, 2019 at 02:15 PM
has failed. My coil failed open (allowing less than the 3 to 5 ohms resistance it's supposed to allow), which resulted in a blown fuse. Yours may have failed closed.
ac compressor on all the time
jerrydc
09:47:57 07/17/19
Check to see if the compressor's clutch is working.
cherry
13:55:45 07/17/19
Re: Check to see if the compressor's clutch is working.
jerrydc
14:07:52 07/17/19
cherry
14:15:42 07/17/19
If the clutch surface looks good, it could be that the coil -
cherry
14:21:07 07/17/19
I don't think the coil can fail in a way to be on
Agent X
12:39:18 07/22/19
If you put econ on, it should disengage the AC
MixManMash
08:02:00 07/22/19
