TwinTurbo.NET: Nissan 300ZX forum - Coolant is circulating through the turbos in all conditions
CarolinaZ_TT
on July 15, 2019 at 11:08 AM
Didn't pressure test it yet
posted by FrozTTy
on July 15, 2019 at 08:58 AM
The coolant return lines from the turbos are rerouted as part of the common "by-pass" procedure done with a plenum pull.
Follow-up to Driver's Side Turbo Coolant Hose
FrozTTy
11:10:01 07/08/19
Couple of things
CarolinaZ_TT
14:04:36 07/09/19
Good thoughts
FrozTTy
20:14:33 07/09/19
Yes it is possible for the turbo hardlines to get clogged.
MixManMash
08:05:25 07/10/19
I'm using my original USDM turbos still (n/m)
FrozTTy
08:17:48 07/10/19
I've seen the hardlines get gunked up on USDM motors
MixManMash
21:37:16 07/10/19
Is there anything you think I should do before digging
FrozTTy
08:21:43 07/10/19
This is a tough area to diagnose/troubleshoot with the
CarolinaZ_TT
09:31:13 07/10/19
Agreed Carolina..... 'good coolant flush'
FrozTTy
10:35:57 07/10/19
Once I have access to the hardlines, could I insert
FrozTTy
10:37:41 07/10/19
Absolutely - I might also pick up a pack of pipe cleaners
CarolinaZ_TT
14:50:11 07/10/19
I have also drained the cooling system completely, even by
MixManMash
21:43:20 07/10/19
Understood, but flushing a leaking system is another topic (n/m)
FrozTTy
08:06:55 07/11/19
As in, I can't even drive around with that flush product
FrozTTy
08:08:19 07/11/19
Time to pressurize the system
CarolinaZ_TT
14:40:56 07/11/19
Thanks again
FrozTTy
07:33:49 07/12/19
FrozTTy
08:58:54 07/15/19
Coolant is circulating through the turbos in all conditions -
CarolinaZ_TT
11:08:51 07/15/19
Good timing on this subject, as I'm highly suspicious that
Woodnutz
07:05:07 07/10/19
With the plenum off, and the transmission out, it is
MixManMash
08:07:12 07/10/19
Very nice on your purchases
FrozTTy
08:20:57 07/10/19
Luckily, it wasn't a catastrophic blowout and I was only a
Woodnutz
14:25:28 07/10/19
