TwinTurbo.NET: Nissan 300ZX forum - Follow-up to Driver's Side Turbo Coolant Hose
Subject Follow-up to Driver's Side Turbo Coolant Hose
Posted by FrozTTy on July 08, 2019 at 11:10 AM
  This message has been viewed 367 times.
Message OP found here:
[ http://twinturbo.net/nissan/300zx/forums/technical/view/1162374/DS-Turbo-Coolant-Line.html ]
I can see most of this hose from underneath the Z.
I have downpipes and can see the bottom of the coolant hose, but not the top.
Looks to me like the hose is just gunk'd up and not actually split/blown.
Question: does this mean the hard pipes would be clogged also?
If I'm able to remove the old hose, how am I able to tell if the lines are ok, and if it was truly the hose causing my leak?
I don't want to go through the painful work come to find out the hard-lines are causing excessive pressure and leak.
Looks to me like the hose has screw clamps and not spring clamps.
Also, I have stock turbos so my downpipes are 4-bolt. Why do I see an extra threaded thing in between 2 of the bolts? They are on both driver and passenger sides.
TIA!!!!
