TwinTurbo.NET: Nissan 300ZX forum - 98 j spec trans issue
Subject 98 j spec trans issue
Posted by Boostjuice on July 07, 2019 at 10:12 AM
  This message has been viewed 390 times.
Message Has anyone ever had an issue with these transmissions? I know the common problem about 3 years ago was the input shaft bearing whine.
I recently bought one to replace my old transmission, it is brand new ordered from concept z. Clutch disc and pressure plate are aligned correctly, the alignment tool slides in and out with ease. The transmission slides on right up until it hits the dowel pins and then just stops, almost like the dowel pin holes in the transmission aren’t big enough. My old transmission was easy to put on and take it off and this thing is being a pita.
